Activity › Forums › Adobe Audition › SoundBooth CS4 – MultiTrack ?
  • SoundBooth CS4 – MultiTrack ?
    Posted by Jim Hines on June 29, 2009 at 12:06 am
    Hello,
    Is it possible to listen to one track through your headphones while simultaneously recording another track? If so, how?
    I’m not using a mixer. Just a USB mic pluged into the sound card. I’m on a PC.
    Thank you,
    jim
    Jim Hines replied 17 years, 2 months ago 2 Members · 2 Replies
  • Larry S. evans ii
    July 15, 2009 at 3:23 pm
    Jim:
    I couldn’t find a way to do this with Soundbooth. I know with Audition you can mark one or more tracks to record as others playback, but Soundbooth seems to have separated the recording function from the multi-track system.
    You might want to look at a demo of Audition 3. I have the Master suite and still bought Audition separately to handle my sound work, because I just don’t feel Soundbooth (at least in CS3 and CS4) is up to doing much more than your basic wedding video type of work.
    You might also consider that a fairly good multitrack mixer board can be had for around $100 (less depending on the number of inputs) and these give the option of doing what you are talking about -playing a track out plus recording in to a final mix.
    Of course, if you are looking to keep the tracks separate for later editing mixing and you just need to hear the audio track for a baseline then Audition is going to be the only solution that I know will keep it separate.
    Larry S. Evans II
    Executive Producer
    Digital I Productions
  • Jim Hines
    July 16, 2009 at 2:02 am
    Thanks Larry,
    I appreciate your response.
    Can’t believe they left that elemental feature off. Oh well.
