Activity Forums Maxon Cinema 4D sound to C4D / quicktime
  • sound to C4D / quicktime
    Posted by Kent Wenger on November 14, 2010 at 2:10 pm
    Greetings,
    I’m new to C4D. My students are creating 20-30 second animated text promos that are rendered to quicktime. I have access to download music files. How can they be added in C4D to the quicktime video file?
    Thanks in advance. kw
    Brian Jones replied 15 years, 10 months ago 3 Members · 4 Replies
  • Adam Trachtenberg
    November 14, 2010 at 7:35 pm
    Add a sound track in the timeline, load the sound file, and make sure “include sound” is checked in render>save settings.
  • Kent Wenger
    November 14, 2010 at 8:58 pm
    Thanks for the response. I have attempted your steps and have negative results. What other checks/steps can I attempt? kw
  • Adam Trachtenberg
    November 15, 2010 at 3:38 am
    Make sure the sound format is one that Cinema recognizes (uncompressed .wav or .aiff). If you turn on the the speaker radio button in the time slider you should hear the sound play when you run the animation in the editor window.
  • Brian Jones
    November 15, 2010 at 3:40 am
    if you are adding a sound track successfully but not getting sound it might be sound file format problems.
    “Sound Formats
    The following sampling rates are supported for sound files:
    11, 22 and 44 kHz
    8-bit and 16-bit
    WAV Import
    Only uncompressed WAV files are supported.
    Markers included in the WAV files are imported into CINEMA 4D.
    AIFF Import
    AIFF-Import
    Mac sound files are also supported.”
    if you know that already, more info please.
