Activity › Forums › Adobe Encore DVD › Sound to buttons?
Sound to buttons?
Posted by Ray Adkins on June 26, 2008 at 2:50 pmCan you set audio to the over state of a button in Encore? If so could someoneplease tell me how to do it.
Ray Adkins replied 18 years, 2 months ago 2 Members · 4 Replies -
Joe Bowden
June 26, 2008 at 7:46 pmThe DVD-Video format doesn’t support anything like this – in DVD-Video, button highlights are used to indicate the selected button. Button highlights are 2 bit graphical layer with no sound support.
However, you can fake this effect by using multiple menus, one for each button with the sound attached to the menu, link each button to its “sound” menu, and then use auto-activate feature on buttons to make the menu switch when the button is selected.
Beware this workaround gets tedious when there are several buttons in the menu, and will not work correctly on a software DVD player (you will have to click on the buttons to switch to the next menu).
Joe Bowden
June 27, 2008 at 2:31 pmNot without disruption, no.
Understand that you’re trying to work around the limitations of the format. Unfortunately, workarounds are seldom perfect.
It’s up to you, but I find working within the limitations of the format usually generates the best result. That’s why I don’t try to paint with an electric guitar, or play a chord with my paintbox. 🙂
Ray Adkins
June 27, 2008 at 5:03 pmWell I guess my client will have to live with no sounds for buttons.
Thanks for the help!
