Activity › Forums › Apple Final Cut Pro Legacy › Sound Sync issues
  • Sound Sync issues
    Posted by Alex Dunn on May 1, 2008 at 10:44 pm
    Hi there. Can anyone help me with this. I’ve recently captured footage from DVCPRO HD tapes (1080i25p) to the DVCPRO HD format (1080 25i) in FCP through my KONA 3. The footage i have of an interview seems to be out of synch with the sound…not sure by how much, but after doing what i’ll explain next, i’m betting it’s about 4 frames!
    I wasn’t too concerned as it’s something i’ve noticed before and thought that i could have made a mistake with the capture (the KONA 3 is new) and i’m fairly happy to re-sync the sound if needs be. The main problem is that i have now opened an old project (DV PAL) that needs a number of sequences printed to DV tape for my client. Upon opening my project it seems that all the sync to the interviews in the project are now 4 frames out!! Very annoying!
    I can’t find anything that could be wrong here within my settings and can’t quite get to grips with it but suffice to say, i could do with a pretty quick solution!
    I don’t have my RAID turned on with my other project and am just running this from a firewire 800 drive. The project has not been touched since about a week ago when everything was fine!! I’ve tried deleting all my render files for the project but this hasn’t helped either.
    If anyone can help with this i’d really appreciate it
    thanks
    Alex
    Alex Dunn replied 18 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
