Activity Forums Audio Sound recorder
  • Sound recorder
    Posted by Nikos Papadopoulos on May 18, 2013 at 7:16 pm
    Hello everyone,
    I made a feature documentary last year mostly with a rode video mic on a canon 5d and the sennheiser 416 on a dvx100a for sound.
    Of course the sound on the 5d was horrible. The sound on the dvx100a +416 was very very good.
    Which was very surprising to me so much as to think that I could actually use the dvx100 for recorder. If it did’t use tapes and was digital I would probably do that.
    So, nowadays I don’t use the dvx100a anymore. Hell, who shoots dv anymore? So i am stuck with the 5d for now until I replace it with another affordable HD, perhaps mark iii, if the magic lantern + Raw wll work or even Blackmagic production camera. We’ll see.
    To the above setup I am looking to add a sound recorder that will be decent enough for years to come. At first I was looking at the Tascam dr-60d. I almost bought it since I am shooting on DSLR. Then i figured out that all this DSLR-targeted promotion makes no sense (to me). I would *never* attach the dr-60d to the bottom of the dslr and go on shooting. I’d need a rig. But I can put ANY small sized portable recorder on a rig. Or i’d hang it on my neck (for one man stuff) or give it to the recordist/booman for bigger projects.
    With that in mind plus the fact that I don’t like the digital knobs instead of potentiometers, plus the fact that from the reviews so far I haven’t read anyone been overly enthusiastic, I thought I would get something tried, proved and with a different form factor. This design realy makes no other sense than sticking the camera on legs without moving it.
    So for my budget I am torn between one of these:
    a) Marantz pmd661 mkii (i need to put my hand very very deep for that one but I am willing to do it if it is really worth the extra money)
    b)Roland R26 (read great things about it)
    c)Tascam dr-60d (only if i get convinced that it’s worth getting it)
    d) any other NOT more expensive than Marantz.
    For the moment I am using Rode video mic which i find decent but thinking of the purchasing later the ntg2 or 3 or 416. So for now, perhaps it doesn’t make a difference to have the videomic on marantz but I am shooting a documentary and a feature film in the fall so I need to get something that can perhaps expand.
    I’ve read great reviews that one could put a mix pre from sound devices and get great results.
    I am trying to build up gear for independent short and feature films, fiction and documentary as I put the numbers now it makes no sense to hire equipment where I live, in Norway.
    Many thanks for your time and help.
    Brent Dunn replied 13 years, 4 months ago 8 Members · 22 Replies
  • 22 Replies
  • Eric Toline
    May 19, 2013 at 12:43 am
    I don’t know much about the Rode video mic but I’m sure it will do the job it was designed for. I’ve gotten vey nice acceptable sound from a 5d. It’s all a matter of setting the levels on the 5d. The 5d preamps are not the best so if you keep the 5d peaks at about -12 on the meters you should be fine.
    Eric
    “I push the RECORD button and hope for the best”
  • Ty Ford
    May 19, 2013 at 3:44 am
    Hello Nikos and welcome to the Cow Audio Forum.
    I’m told the 5D Mk iii audio is noticeably better than the Mk ii, but I have not made a test yet.
    The NTG-3 is worth the extra money for a shotgun. You’ll also benefit from a non-interference tube boom mic like a Audio Technica AT4053b or Audix SCX-1HC.
    Your audio will not improve much until you start using a boom mic and getting closer to your talent. A camera mounted mic, no matter how good, just won’t do it.
    Unlike cameras, audio gear lasts a long time. If you’re doing professional work you can’t afford to buy cheap.
    Regards,
    Ty Ford
    Cow Audio Forum Leader
    Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
    Ty Ford Blog: Ty Ford’s Blog
  • Nikos Papadopoulos
    May 19, 2013 at 8:26 am
    Thank you both.
    I am planning to use boom for the fiction work but mounted mic on camera for static interviews.
    Actually the main reason i am considering a better recorder than, say, a preamp to go straight to camera is for the fiction work. Boom is a necessity for sure. Also because I want to have room to expand.
    The reason I am a bit confused with all these recorder options is that as filmmakers we do not have the expertise that you audio guys have. And trying to find a decent budget solution makes things even harder. It is a bit embarrassing that in the last 5(?) years many independent people bought into the H4n hype. And I mean some professional sound guys too. From what I understand the pre amp quality on H4n leaves a lot to be desired.
    So, in any case an external recorder is a must even if a will get a mark3 or a BM production camera or whatever in the future. I also believe that audio equipment are not so easy disposable as all these image capture devices we get. And that is why I am looking for the best possible quality for my budget.
    I’ll have to look into the non-interference tube boom mics , I don’t know much about these but I am definetely thinking about ntg3 as I ‘ve read great things.
  • Ty Ford
    May 19, 2013 at 1:14 pm
    Hello Nikos,
    This may help you with understanding about mics: https://www.youtube.com/watch?v=IaUSXP-a3hA
    You can use a locked down boom or lav for a static interview. It will greatly improve the quality of your sound.
    Here’s how to rig the boom. https://www.dropbox.com/s/2gl46vmss7gpx9x/Ty%27s%20Boom.mov
    You have to download this video to see it. DropBox will play the audio, but not the video.
    Regards,
    Ty Ford
    May 19, 2013 at 2:12 pm
    Thanks Ty !!
    Quite a difference between the 416 and the hypercardioid .. And I believed I could get away with just an NTG3 !! I think i will seriously look into the possibility of getting a system mic with 2-3 different polar patterns. Perhaps sennheiser ME/K6.
    What about the recorders. Which one from the ones I mentioned would you choose?
    Many thanks again.
  • Chris Tompkins
    May 19, 2013 at 2:31 pm
    I like the look of the Tascam DR-100mkII.
    Chris
  • Ty Ford
    May 19, 2013 at 2:33 pm
    You will be disappointed by the mE/K6. That’s for student films. The NTG3 is much better than that.
    The AKG BLue Line may be an option, if they are still around.
    Regards,
    Ty Ford
    May 19, 2013 at 2:41 pm
    I had the impression that it’s not a good idea to use a shotgun and that it’s better to have a less directional mic for indoors.
  • Ty Ford
    May 19, 2013 at 2:55 pm
    Nikos,
    It is not a good idea to use a shotgun indoors or out of doors in any highly reflective environment.
    Did my video not make that clear?
    Regards,
    Ty Ford
    May 19, 2013 at 3:01 pm
    Ty, yes it was perfectly clear.
    That is why i started thinking to go modular… up to now I thought that a shotgun could be used all around.
    On the other hand if no modular system can give a decent broadcasting quality, I guess I’ll have to get the ntg3 after all plus the Audix SCX1/HC for indoors.
Page 1 of 3
