Activity Forums AJA Video Systems Sound problems on LH and IO
  • Sound problems on LH and IO
    Posted by Jadranko Gudan on November 22, 2005 at 11:40 am
    I have two systems one is 2x2Ghz/10.4.3/FCP 5.0.3/Aja IO (drivers version 2.1) and another is 2×2.5GHz/10.4.2/FCP 5.0.2/Kona LH (drivers version 1.1.5) and am planing to move both of them from QT 7.0.2 to 7.0.3.
    I know that all of you will say that if it is not broken then I should not fix it, but it looks like it is broken. Every now and then we are losing one channel of sound on both systems (well, never at the same time, but on both systems). From what I can see the only same thing on both systems is QT version, so I am pressuming it is responsible for the problem.
    The only problem is that I did not hear that either Kona LH or IO drivers are working fine with QT 7.0.3.
    Is it safe to upgrade QuickTime?
    Thank you,
    J.
    Heinz Tobler replied 20 years, 10 months ago 3 Members · 2 Replies
  • Jerry Hofmann
    November 23, 2005 at 3:18 am
    Make sure you are running all of the latest drivers for both and you should be OK. If you aren’t after that, then it might be time for a totally clean install if you didn’t do this when (if) you upgraded to Tiger. I really think that just “upgrading” to Tiger from an earlier OS is just asking for problems.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Heinz Tobler
    November 23, 2005 at 1:55 pm
    Jadranko
    I’m working in PAL also. I have an Kona LH that unfortunatly does not work.
    The problem is the software! I did not found out yet which one, all i can say is
    OS 10.4.3, FCP 5.03, QT 7.03 and the driver 1.1.6 is a configuration that won’t work.
    cheers, Heinz
    EyeMix GmbH
    zurich switzerland
    kona sd/LH, pal
    http://www.eyemix.ch
