Activity › Forums › Apple Final Cut Pro Legacy › sound problem
  • Posted by Florin Iosif on November 1, 2009 at 3:37 pm
    I am having some problems with adding the edited sound in fcp project.
    It is working well if I export in dv format the edited movie and then attach the edited sound and export again.
    I am recording the sound with Edirol R-4. Can you tell me the setting which will work?
    Nicolas Bigler replied 16 years, 10 months ago 3 Members · 6 Replies
  • Nicolas Bigler
    November 1, 2009 at 8:33 pm
    What kind of sound problems? Can you be more precise.
    On my side I am also experiencing sound problems.
    Since I upgraded to Snow Leopard, every time I try to export video that are >10 minutes long the audio just export as saturated sound after a few minutes.
    It seems to be due to snow leopard as when I plug the same hard drive and export the same project from my old mac (running os x 10.5.8 and the same FCP version) it just works fine.
    The computer failing sound export’s configuration is :
    MacBookPro 2.4GHz 2GB ram
    Final Cut Pro studio 2 (FCP 6.0.6)
    Quicktime 7.6.3 (630)
    I have been trying to export using FCP’s Compressor or Export/Quicktime movie or Export/Using Quicktime Conversion and they all give the exact same results.
    an example of a failed audio in a podcast can be found at: here the problem start around 1/4 of the movie and the audio looks like this
    Is it a similar problem to yours?
    Anybody experiencing the same? Any ideas?
    Nicolas
  • Nicolas Bigler
    November 1, 2009 at 8:52 pm
    Nicolas
    Nicolas Bigler
    https://www.bigloose.com
  • Michael Gissing
    November 1, 2009 at 9:40 pm
    [Nicolas Bigler] “Any ideas?”
    I am not sure why you would upgrade to Snow Leopard unless you were upgrading to FCP 7 as well. I wouldn’t recommend upgrading an OS and running older versions of FCP on it.
    I think you have probably found one of many issues with running old version on Snow Leopard. Stick to Leopard.
  • Nicolas Bigler
    November 2, 2009 at 5:59 pm
    well on this computer I can’t really downgrade and the other computer is old and slow…
    So I just have to hope some has a solution or that Apple will release a fix soon. I just upgraded a few month from FCP 3 to 6 and I don’t have the budget yet to upgrade FCP7…
    Nicolas Bigler
  • Florin Iosif
    November 2, 2009 at 8:41 pm
    The problem with the edited sound is that it works perfectly for 4 minutes and then it has a delay and I cannot fix it.
    Even if I open the sound from camera which works and try to replace that one with edited one, it doesn’t wanna work.
  • Nicolas Bigler
    November 29, 2009 at 3:17 pm
    So it doesn’t look like we have the same problem. But for me, luckily enough the os x 10.6.2 update fixed the problem. Everything back in order.
    Nicolas Bigler
