Activity › Forums › Apple Final Cut Pro Legacy › Sound plugin
Sound plugin
Posted by Jack Fox on January 21, 2008 at 8:37 pmIs there a plugin that works like the broadcast safe filter to assure that the sound is within preferred limits (-18)?
jmf
Jack Fox replied 18 years, 8 months ago 3 Members · 4 Replies -
Peter Wiggins
January 21, 2008 at 9:14 pmSure, try the compressor/limiter -play around with the settings until you get nice compression when approaching the limit.
Peter
Michael Gissing
January 21, 2008 at 11:01 pmNot really. The limiter is clip based so a bunch of clips limited to a set maximum, then mixed together will exceed broadcast levels.
FCP is not an audio mastering tool as you can’t bus mix to create stem elements or peak limit mixes, only clips. The compressor limiter in FCP is functional but not a patch on units found in DAWs and mixers.
Jack Fox
January 22, 2008 at 12:07 amI set the threshold at -18, and the rest at default: ratio at 6, Attack Time at 5 and Release Time at 100. Some audio jumped to almost -12 but the audio clip was acceptable.
jmf
