Activity › Forums › Adobe After Effects › sound off when render completed
Posted by Yumibobcat on March 24, 2007 at 9:46 pmhow can i turn off the alerting sound that plays when rendering is completed?
Yumibobcat replied 19 years, 5 months ago 2 Members · 2 Replies -
Andy Burmeister
March 25, 2007 at 1:14 amYou can change this in your “Adobe After Effects 7.0 Prefs.txt” file which you can find under C:\Documents and Settings\Administrator\Application Data\Adobe\After Effects\7.0
Go to the [“Misc Section”] in the pref. file. and change the value under
“Play sound when render finishes” from “1” to “0”
Yumibobcat
March 31, 2007 at 4:39 pmHi Andy.
Thank you for the helpful information! 🙂
How do you copy and paste a layer with its keyframes into another composition within the same file in AfterEffects? I just did ‘copy’ and ‘paste’ a layer from Comp 1 to Comp 2, but it didn’t work.
(I’m using a Mac by the way…)
yumi
