Activity Forums Maxon Cinema 4D Sound Object in 10.5
  • Sound Object in 10.5
    Posted by Tom Slattery on March 31, 2008 at 9:06 pm
    When making a sound object to scrub to…
    Null Object > Add Special Track > Sound > Assign sound file (AIF)…
    The file does not load. I’ve even converted to WAV just in case C4D was being picky. I’ve done this in previous versions without an issue.
    I also copied in an object from an earlier version that did work. It scrubs OK, but it will not load a new sound file.
    Is this a bug?
    ~TPS
    Tom Slattery replied 18 years, 5 months ago 2 Members · 2 Replies
  • Nolan Scott
    April 1, 2008 at 1:05 am
    Using R 10.506 / OSX 10.4.11
    Please make sure that your sound-file is 44.1 kHz / 16 Bits (.aif/.wav),
    and check “Play Sound During Animation”.
    Cheers
    Nolan
  • Tom Slattery
    April 1, 2008 at 1:39 am
    That was the ticket. The file supplied was 48.00 khz.
    You just saved me a day of time!
    Thanks a million!
    ~TPS
