Activity Forums Apple Final Cut Pro Legacy Sound Not Synching To 720p Sequence
  • Sound Not Synching To 720p Sequence
    Posted by Andrew Hampy on April 29, 2009 at 1:53 am
    Current work flow
    Picture filmed on 35mm film 24 fps, telecine capture to 720p (59.94 fps)
    and
    Picture filmed on 35mm film 24 fps, telecine capture to NTSC Anamorphic 16×9 (29.97 fps)
    Sound captured using Marantz PMD671 Portable Solid State Recorder (96khz)
    I have 2 sets of picture one NTSC (29.97fps) and one 720p (59.94fps). The sound was synced up to the NTSC 29.97 and resulting sound design was all done at 29.97. I would like this sound design to also sync to the same edit done with footage that is 720p (59.94fps) I have tried several options but nothing seems to sync up. What would be the best solution.
    Thanks for your response
    John Fishback replied 17 years, 4 months ago 2 Members · 1 Reply
  • John Fishback
    April 29, 2009 at 4:21 pm
    Are the pictures in sync? Try dragging them both into a timeline and compare where the edits happen toward the end. I wonder if there was a sync issue during the telecine.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
