Activity Forums Apple Final Cut Pro Legacy Sound mix in FCP/Soundtrack pro
  • Sound mix in FCP/Soundtrack pro
    Posted by Robert Real on July 9, 2010 at 10:44 pm
    Hello,
    I have a question regarding the best procedure to follow to improve a sound mix.
    I have a cut of a short movie which lasts approximately 25 minutes and uses around 100 clips. When it was recorded, there was a rough stereo sound mix sent to the cameras and I did the first version of the cut using this sound mix.
    Now I have access to the individual audio tracks (5 tracks, recorded using Pro tools and converted to OMF) and I think I can get a much better mix than the one that was sent to the camera.
    My question is about what you would think the best procedure to follow would be in this case. I can see two ways of doing this, and find both very labor intensive and wonder if there is a better/more canonical way of doing this:
    * For each .dv clip, erase the original soundtrack, and replace it by a newly mixed one. I would do this by putting each clip in its own sequence, adding the audio mix rendering and exporting to a .dv file. This would take some time.
    * Delete the audio track of the final cut and try to mix the audio there directly.
    Is there a better way to achieve this altogether? Are there any potential pitfalls to either of these approaches that I need to be aware of?
    –Robert
    Michael Gissing replied 16 years, 1 month ago 2 Members · 1 Reply
  • Michael Gissing
    July 10, 2010 at 3:43 am
    Firstly FCP doesn’t import OMFs so the multi track files should be sourced directly, preferably as broadcast wav.
    Secondly, find someone with an up to date Fairlight running dream2 software. A newish feature is the ability to relink a stereo file to multi track files and import the missing tracks into a project. Important to the process is that the original files were broadcast wav and had the same timecode as the multi track broadcast wavs.
