Activity Forums Apple Final Cut Pro Legacy Sound levels too low
  • Sound levels too low
    Posted by Todd Burrell on July 17, 2006 at 1:32 pm
    I am working on a trade video and am having trouble with my sound levels. Part of the video is VO from a production house. When I bring this into FCP the levels are coming in at -18db when they should be coming in at -12db. Is there an overall setting that I have set wrong? This has been a issue with several projects I have worked on. Any help is greatly appreciated.
    Richard Harrington replied 20 years, 2 months ago 3 Members · 5 Replies
  • Richard Harrington
    July 17, 2006 at 2:12 pm
    Post house may ahve mastered to that… some formats like digibeta use a -18 db levels. I would suggest making sure tracks are panned center… then duplicate the audio by Option dragging a ssecond copy to a lower track.
  • Todd Burrell
    July 17, 2006 at 2:39 pm
    Is it better to pan center or should I copy the track and pan one left and the other right? Thanks for the info.
    July 17, 2006 at 2:41 pm
    Unless you have stero effects…. pan narration center… leave music panned left and right
  • Thaxter Clavemarlton
    July 17, 2006 at 5:53 pm
    No need to “duplicate” the audio tracks to add level (an possibly complicate the edit down the line).
    Just add the Audio Filters > Apple > AUPeakLimiter and adjust the “Pre-gain” to any level you want.
    July 17, 2006 at 6:27 pm
    Filters require rendering…. duplicating a track does not
    Either way works
