Activity › Forums › Apple Final Cut Pro Legacy › Sound Level too low-Compressor
  • Sound Level too low-Compressor
    Posted by Sascha Engel on November 18, 2009 at 1:14 am
    Hi Everybody,
    i have quiet a problem: When I encode my film in Compressor too use it later in DVD Studio Pro, I use the DVD encoding settings High-Quality for 90min and the Dolby Sound for Audio, which is in the same Folder. For some reason, the encoded sound is extremly low, the Volume goes down drastically. Compared to an AIFF export from FCP it’s less than half of the Volume.
    How can I push the Volume in the Compressor up?
    Thanx a lot!
    Greetz,
    Sascha
    Rafael Amador replied 16 years, 10 months ago 4 Members · 6 Replies
  • Rob Grauert
    November 18, 2009 at 1:45 am
    When you drop the Dolby preset onto your file, load it into the Inspector. In the Encoder pane, go into the Audio tab. At the bottom there is Dialog Normalization. Set that to -31dBFS.
    I encountered this a while back and had a hard time understanding it in the manual, but I walk away understanding that setting it to -31dBFS will leave your audio untouched.
    Robert J. Grauert, Jr.
    http://www.robgrauert.com
  • Rafael Amador
    November 18, 2009 at 2:04 am
    Hi Sascha,
    Set Preprocessing> Compression Preset> NONE.
    Rafael
    http://www.nagavideo.com
  • John Pale
    November 18, 2009 at 3:01 am
    Both Rafael and Rob are correct.
    Make your own preset to reflect their advice. Unfortunately the preset included in Compressor is more appropriate for a movie theater sound system than a normal set up.
  • Sascha Engel
    November 18, 2009 at 9:47 am
    To everybody who responded – thanx a lot – I will try it right now!
  • Sascha Engel
    November 18, 2009 at 10:16 am
    Thanx to you & Rafael! I did a cobination of both and it did the job! GREAT!
  • Rafael Amador
    November 18, 2009 at 12:36 pm
    I was suffering the same story till Walter gave me the tip.
    Info flow.
    Rafael
