Activity Forums Apple Final Cut Pro Legacy Sound issues. Please Help
  • Sound issues. Please Help
    Posted by Paul Ladd on January 30, 2007 at 11:39 pm
    Hello everybody. I am editing a video for a client that consists of a bunch of single interviews shot in many different conference rooms. My client used a very cheap directional mono microphone for the audio and it is terrible quality. My main issue is what appears to be an electrical hum (different for each room). I tried the hum remover and it was of little help. I also tried the 32 band graphic equalizer and have not been able to isolate the sound with it. I have used the audio filters in the past successfully, but for some reason i am having no luck this time. Any suggestions?
    Ed Dooley replied 19 years, 7 months ago 2 Members · 4 Replies
  • Ed Dooley
    January 31, 2007 at 4:21 pm
    Soundsoap is pretty good.
    Ed
  • Paul Ladd
    February 1, 2007 at 2:18 am
    Are there nay other tips or tricks within FCP that I could try?
  • Ed Dooley
    February 1, 2007 at 6:05 am
    For regular, single frequency hum issues, you should be able to isolate it
    pretty easy with the 3 band EQ or graphics equalizer.
    Ed
  • Ed Dooley
    February 1, 2007 at 6:08 am
    Here’s a P.S.: Have you tried the 3 band EQ and raising the audio level
    to the max as you scrub through the frequencies? That will highlight
    the offending frequency better. Then you can dial that one down.
    Ed
