Activity Forums Audio Sound is distorted but not clipping??
  • Sound is distorted but not clipping??
    Posted by Sally Obrien on August 2, 2011 at 2:55 pm
    I did a shoot a while back and my audio sounds really distorted; although it’s not peaking in the waveforms, so I’m unsure of what went wrong. Here’s a sample of the sound:
    https://www.vimeo.com/27182326
    Two questions:
    1) Where do you think this could be coming from? (I’m afraid a faulty lav mic might be the culprit)
    2) Is there anyway to fix this type of thing?
    Sal
    Cory Lusk replied 10 years, 11 months ago 4 Members · 6 Replies
  • Peter Groom
    August 2, 2011 at 3:22 pm
    HI Sal
    I dont think its the mic ,I think its front end analogue distortion on the input to the desk/ mixer/ or recorder / camera. It has a n analogue grungy tone. Basically too much level going into the device, not necessarily too high a recording level.
    Ive has a play with some restoration software in 10 mins I had free. This distortion is almost gone, but its a little watery. Certainally better. Id add some music that will hide things too.
    You should consider using track 2 only. It is not distorted at all, may be the camera mic. A little more distant and hissier as its low level, but can be cleaned up with a bit of eq and is your best shot (INHO)
    Ive attached an mp3 of my playing befor e i ran out of time.
    Cheers
    peter
    2725_distortionplay.mp3.zip
    Post Production Dubbing Mixer
  • Sally Obrien
    August 2, 2011 at 3:33 pm
    Wow, Peter, that clips sounds beautiful! What kind of restoration software do you use? iZotope?
    Sal
  • Ty Ford
    August 2, 2011 at 5:57 pm
    Sally,
    Next time wear headphones on both ears. You will hear the bad stuff before you hit the record button.
    Apparently you were only overdriving one track, the lav. The other track, as he mentioned, probably the camera mic saved your butt.
    Regards,
    Ty Ford
    Audio Forum Leader
    Cow Audio Forum Leader
    Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
  • Peter Groom
    August 3, 2011 at 1:00 pm
    Yes izotope. Its a blend of de clipper in izotope, eq, AND blending in your track 2 material. Its worth a play. Your main audio is pretty awful , but using a few tools in combination its possible to get it back into useable land, and as i suggested, put some music over it and youre there!
    Peter
  • Peter Groom
    Ty is right.
    Ears in ON mode.
    Peter
  • Cory Lusk
    September 18, 2015 at 1:03 pm
    I have audio that has low levels, but sounds like it’s clipping. Is there something I can do in Adobe Audition?
