Activity › Forums › Apple Final Cut Pro Legacy › sound fx with livetype projects
  • David Bogie
    June 27, 2005 at 2:48 pm
    LT still doesn’t support audio so the answer is yes and no. Build the effect, export it to FCP, add your sound effects, export it using the Animation codec to preserve the alpha. Each time you use the clip, the sfx will be there but no magic involved.
    bogiesan
