Activity Forums VEGAS Pro Sound Forge added black bars top/bottom/general advice of SF workflow :(
  • Sound Forge added black bars top/bottom/general advice of SF workflow :(
    Posted by Ben Edwards on August 20, 2009 at 12:05 pm
    I had a event that was very quiet even when I set the volume line to Max. I Therefore decided to use the Sound Forge integration and boost he volume in Sound Forge. This seemed to work, even though it took quite a long time to save (I do however sometimes get (‘media offline’ writern on the clip but the thumbnails are there). Thing is when I go back to Vegas although the sound is boosted I get a black stripe at the top/bottom of the clip. This even shows up if I load the clip from the Media Bin to the trimmer! I have tried all sorts of things (aspect ration etc.) but cant fix it.
    I guess my use of Vegas/Sound Forge integration was not quite correct. Can anyone give me advice/guidelines on this. What would be great was a tutorial that covers taking an event in Vegas into Sound Forge, tweaking sound and then saving the results back to Vegas. I have goggled but no luck.
    Regards,
    Ben
    Danny Hays replied 17 years, 1 month ago 4 Members · 8 Replies
  • 8 Replies
  • Theo Van laar
    August 20, 2009 at 12:36 pm
    Hi Ben,
    Normally, you would indicate your favorite audio editor in the preferences. After having done that, you only have to context (right) click the audio event and select the option to edit a copy of the audio in your favorite editor. This editor will launch and you make your effect. A copy will be rendered automatically. Thats all.
    Theo
  • Ben Edwards
    August 20, 2009 at 12:50 pm
    This is what I did. Sound Forge was the editor. When I returned to Vegas, after Sound Forge Saved, that’s when the black lines appeared.
  • Theo Van laar
    August 20, 2009 at 1:29 pm
    So soundforge made a new copy of the edited audio for you? Then you should be able to delete the original event from the timeline AND the project and import it again.
    Theo
  • Ben Edwards
    August 20, 2009 at 1:40 pm
    I thought the Vegas and Sound Forge were supposed to be properly integrated. What I really need is a tutorial.
  • Theo Van laar
    August 20, 2009 at 1:53 pm
    Ofcourse Vegas and Soundforge should work together perfectly. I never saw your problem in Soundforge 8 or in Soundbooth CS4.
    But could you solve the problem this time by re-importing the original event?
    Theo
  • John Frey
    August 20, 2009 at 5:45 pm
    Ben, it sounds like you ‘Opened in Sound Forge’ rather than ‘Open a Copy in Sound Forge’. The former sends audio and video into S. Forge, and if you work on it there and save it, the video can be affected. Opening a Copy sends only the audio portion of the file.
    John D. Frey
    25 Year owner/operator of two California-based production studios.
    Digital West Video Productions of San Luis Obispo and Inland Images of Lake Elsinore
  • Ben Edwards
    August 20, 2009 at 9:56 pm
    Thanks a lot, I was coming to that conclusion.
  • Danny Hays
    August 21, 2009 at 1:34 am
    Have you tried normalizing and or compressing the audio right in Vegas? Right click the audio event, switch, normalize, or add a compressor as an effect. Hope this helps, Danny Hays
