Activity Forums Adobe After Effects sound expression
  • sound expression
    Posted by Trev on June 11, 2007 at 3:22 pm
    hi, i’ve ‘converted audio to keyframes’ (keyframe assistant) in my comp and applied the pick whip of an objects scale to the sound slider of the audio null created in my comp. all good but i was wondering if there was a way to add another slider to even or make a bit more subtle to the scaling movements. I’ve tried to lowering the audio level and doing the same thing, this does decrease the the general size of the scaling, but when you scale up the object, the relative distance between the audio peaks remain the same… anyway hope some of this makes sense… thanks for any help trev
    Mike Clasby replied 19 years, 3 months ago 2 Members · 1 Reply
