Activity Forums Audio Sound effects and music library browsing
  • Sound effects and music library browsing
    Posted by Sacha Sojic on June 4, 2010 at 8:38 pm
    Hi guys,
    I’m wondering if anyone can suggest a Mac application that facilitates browsing and searching of sound effects and music libraries. I’m finding it difficult to search through terabytes of foley and sound effects if I can’t easily bring up the waveform and play out a portion of the track. For a Final Cut editor there must be something better than Apple’s Soundtrack Pro to do this?
    S. Sojic
    Montreal, Quebec
    Sacha Sojic replied 16 years, 3 months ago 3 Members · 4 Replies
  • Thaxter Clavemarlton
    June 5, 2010 at 11:11 am
    [Sacha Sojic] “I’m finding it difficult to search through terabytes of foley and sound effects if I can’t easily bring up the waveform and play out a portion of the track. “
    Bring up the waveform from what source?
  • Sacha Sojic
    June 5, 2010 at 1:34 pm
    I have a complete 2Tb disk full of sound effects and music for use in my edits. I’m simply looking for an app that will facilitate searching and listening to tracks. I like to be able to rapidly see the waveform of a track so I can pinpoint hits, highs and lows. I guess I’m looking for a browsing utility for sound editors. Does that make any sense?
    S. Sojic
    Montreal, Quebec
  • Antony Tsoukatos
    June 5, 2010 at 4:17 pm
    AudioFinder is relatively cheap and will defitely do what you’re after:
    https://www.icedaudio.com/
    Soundminer is the choice of the pros. Terribly more expensive and it does a lot more than what you describe you’re after. But it’s there if you want to have a look
    https://www.soundminer.com/SM_Site/Home.html
    But for a temporary and budget-concious solution iTunes can do the trick. Launching iTunes while pressig the alt key gives you the option of working with multiple libraries. So, you could have a library for all your library tracks and separate for all the SFX. The searching facility is there and by utilising tags one can achieve a lot. But not that snappy and of course there is no waveform view option.
  • Sacha Sojic
    June 8, 2010 at 4:24 am
    That’s fantastic Antonis. AudioFinder does the trick perfectly. Thanks for the heads up.
    Best,
    S. Sojic
    Montreal, Quebec
