Activity Forums Maxon Cinema 4D Sound Effector not working
  • Sound Effector not working
    Posted by Jonathan Pears on November 20, 2008 at 11:02 pm
    Hey Everyone
    I am having an issue with the sound effector. I am making a speaker using mograph, and i have used a linear cloner for it too.
    My issue is that when i select a mp3 to use for the music in the sound effector, the frequency graph isn’t being generated and there is no effect?
    Any Ideas?
    thanks!
    Claude Johnson replied 16 years, 7 months ago 3 Members · 4 Replies
  • Adam Trachtenberg
    November 20, 2008 at 11:52 pm
    Cinema doesn’t support mp3 format. You’ll have to converted it to a .wav file.
  • Jonathan Pears
    November 20, 2008 at 11:54 pm
    Perfect – thanks!
    On a side note – isn’t that slightly ‘behind the times’ for a modern day graphics software?
  • Adam Trachtenberg
    November 21, 2008 at 12:04 am
    [Jonathan Pears] “On a side note – isn’t that slightly ‘behind the times’ for a modern day graphics software?”
    I would say so. They have updated their supported sound formats since I’ve been using Cinema (since v6). Even the .wav support is pretty limited (use PCM).
  • Claude Johnson
    January 21, 2010 at 9:43 pm
    The following sampling rates are supported for sound files (at least in R11)
    11, 22 and 44 kHz at 8-bit and 16-bit
    WAV Import
    Only uncompressed WAV files are supported.
    Markers included in the WAV files are imported into CINEMA 4D.
    AIFF-Import
    iMac 24″, OSX 10.6.2, Vue 8 xStream, modo 401, C4D 11.5
    https://www.claude3D.com
