Activity Forums Maxon Cinema 4D Sound Effector Issue – animation not rendering
  • Sound Effector Issue – animation not rendering
    Posted by Eli Magaziner on September 29, 2015 at 11:51 pm
    Hey
    I’m trying to use the sound effector to make a simple waveform animation,
    but I can’t get it to work: in the editor I can hear the audio and the animation works fine-
    but when I render it the animation is stuck on the first frame – and it won’t render.
    1- the sound file is legit: WAVE 44100 Hz Stereo, 16-bit
    2- I tried to re-link the sound file, and I restarted cinema and the PC
    3- I tried the same process on my macbook and it worked, so I really don’t know what the issue is
    4- in the Render Settings when i change “Fields” from “None” to “Even First” the animation is working and it renders – but with scan-lines from other frames (I don’t even know what that means)
    5- (I know I can bake it)
    Christopher Hegenberg replied 10 years, 9 months ago 3 Members · 2 Replies
  • Paolo Rave
    December 9, 2015 at 8:25 am
    I am having the same issue here.. Are you team rendering?
    I found out that rendering just on one machine (in queue or picture viewer) solved the issue for me.
    cheers!
  • Christopher Hegenberg
    December 22, 2015 at 10:04 pm
    the update to 16.050 worked for me…
