Activity Forums Maxon Cinema 4D Sound Effector creates annoying echos
  • Sound Effector creates annoying echos
    Posted by Andy Henik on August 6, 2017 at 10:07 am
    I’m working with Cinema 4D R15 for quiet a while now, and it is the first time I use the Sound Effector in Cinema 4D.
    However the sound is in Wav format 16 bit, and I can hear it play, but it creates annoying echo sounds and delays, effecting the clones with the same problem, which make it hard to create something professional from it.
    Even when I make a Preview, I get the same results.
    What am I doing wrong?
    1. Do I have to change something in the Prefference setting in Cinema 4D?
    If there even are any related settings, because I didn’t find any.
    2. Do I need a special Sound card to overcome the problem? No one ever talked about this in any Tutorial I found.
    I really do solve this problam ASAP, since i work on a project for a client on a tight schedual.
    Thanx for every help
    Andy
    Andy Henik replied 9 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
