Activity › Forums › Apple Final Cut Pro Legacy › Sound editing
Sound editing
Posted by Holly Arnold on May 27, 2009 at 3:20 pmI’m using Final Cut Express to edit a video that has a lot of background fuzz on the audio.
Is there anyway to strip this out without losing the audio over it?
Rob Brambila replied 17 years, 4 months ago 4 Members · 3 Replies -
John Fishback
May 27, 2009 at 3:30 pmThere are a number of programs that can probably help. Apple’s Soundtrack Pro has noise reduction capabilities. If you search the Cow for noise reduction you should find others.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
24″ TV-Logic Monitor
Final Cut Studio 2 (up to date)Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Matt Sepeta
May 27, 2009 at 3:43 pmFC can not do too much with audio. Try adding a 3 band EQ and fiddling with that, you may be able to isolate some of the frequencies the buzz is from and lower them?
Good Day
Rob Brambila
May 27, 2009 at 5:24 pmA parametric EQ would be of more help. Try “sweeping” for the correct frequency by setting the Q to 1 the gain to 20 and “sweeping ” the center frequency to find the offending noise. Turn the main volume lower as this will make it loud. When the offending noise is loudest turn the gain to -20 and move the Q up to taste. This should remove a great deal of the noise in the audio track.
Rob Brambila
System Engineer
Promax Systems
rob.brambila@promax.com
http://www.promax.com
