Activity › Forums › Audio › Sound devices 302 TA3 out to camera (wireless)
  • Sound devices 302 TA3 out to camera (wireless)
    Posted by Alex Grassi on February 27, 2015 at 10:54 pm
    Hello to everyone!
    I am trying to figure out the best and efficient way to send a stereo mix down from the mix out of a 302 (TA3) to a camera in through wireless.
    Would that be possible with a single wireless system (transmitter and receiver)?
    If not, would that be worthy to modify the TA3 circuit in a way to have a mono summed mixdown (as I would use it as a reference/backup only)
    Thanks a lot for a reply!!!!!!
    Alex Grassi
    https://alterale.wix.com/alexgrassi
    alterale@yahoo.co.uk
    +44 7707 698983
    Eric Toline replied 11 years, 6 months ago 3 Members · 3 Replies
  • Ty Ford
    March 1, 2015 at 9:28 pm
    Hello Alex,
    Unless you have two channels of wireless, you can not transmit in stereo.
    Regards,
    Ty Ford
    Cow Audio Forum Leader
    Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
    Ty Ford Blog: Ty Ford’s Blog
  • Alex Grassi
    March 1, 2015 at 9:36 pm
    Hi Ty,
    Thanks for the response!
    Alex
    Alex Grassi
    +44 7707 698983
  • Eric Toline
    March 4, 2015 at 1:38 am
    The TA3 mix out is a 2 channel summed (mono) mix from the 302. Wire the feed from the 302 to your wireless transmitter with both pins 2 & 3 of the TA3 connected to your transmitters microphone input connector. Be aware that the mix out is a line level feed and could be to hot for a mic level input. Some transmitters will allow switching the tx mic input to line level by connecting the incoming audio feed to a different pin in the tx connector.
    “I push the RECORD button and hope for the best”
