Sound Devices 302 and Zoom H4N?
I while back I came across this video and wanted to try this out.
https://www.youtube.com/watch?v=cRNd9DT0_is
Then I started thinking, we just purchased the new Canon c100 mII, which can record uncompressed audio in AVCHD. So I wouldn’t need to capture using the Zoom and sync in post. Well, what if I wanted to use the Zoom H4N as a back up recorder, thus capturing dual system sound anyway. Is it possible to do this with the SD 302, camera and Zoom H4N
I have a typical interview set up with 1 LAV mic and 1 BOOM mic coming into ch. 1&2 on 302 at MIC level. I plan to send the LINE level outputs to our Canon c100mII, but would also like to send an output of both channels to our Zoom H4N to capture dual system sound as backup. Is this possible? Is this possible using the TAPE OUT/MIX OUT via the TA3 connector? The TA3 to XLR would only cover one channel or down mix the output. Is there a way to output both channels independently via a splitter cable of sorts into the Zoom LINE inputs using 1/4″ as Roland describes above?
Isn’t this a pretty standard thing to capture audio from field mixer to camera and to an audio recorder. What’s the best way to set this up? Have I over thought this?
iMac 3.5 Ghz Intel Core i7
16 GB of RAM, NVIDIA GeForce GTX 780M 4096 MB
External RAID 5 in T-Bolt Chasis using eSata
BMD Decklink Studio 2, FSI BM210, KRK Rokit 5s, Mackie 802Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
