Activity Forums Audio Sound Clipping at -20db
  • Sound Clipping at -20db
    Posted by Douglas Villalba on December 14, 2005 at 3:32 am
    I have just finish a day of recording sound for a TV commercial shot with 35mm film. The I had the meter at no more than -12db and sounds clipped and it also shows on wave form not as clipped but cut off the top.
    I have to continue shooting tomorrow so if anyone has any idea, please let me know.
    I used an M67 Senn. and also a studio mic. for some voice over and they both sounded the same. I even used different cables for the different mics. The only common denominator was a Marantz solid state recorder that the director brought himself(WAW recorder).
    Douglas Villalba
    https://www.dvtvproductions.com
    dvillalba@dvtvproductions.com
    John Fishback replied 20 years, 9 months ago 4 Members · 7 Replies
  • 7 Replies
  • Frank Nolan
    December 14, 2005 at 3:40 am
    What meter was showing at -12? Were you going through a mixer? Explain the signal flow from mic to recorder.
  • Douglas Villalba
    December 14, 2005 at 3:50 am
    thanks for the quick responce.
    I was going directly to the recorder
    Douglas Villalba
  • Douglas Villalba
    December 14, 2005 at 3:55 am
    This looks like the one I used.
    Marantz PMD670 Professional Solid-State Recorder
    Douglas Villalba
  • Bouncing Account needs new email address
    December 14, 2005 at 4:20 am
    Sounds like you’re over-driving the imput preamp.
    Turn down the TRIM control on the input and/or switch the “attenuator” in on the Mic(s).
  • Frank Nolan
    December 14, 2005 at 4:24 am
    If the meters on the marantz were reading -12, it sounds like you were clippling at the mic. Then again it could be a setting in the recorder. Is there a limiter on the recorder? How far was the mic placed from the talent? Was anyone monitoring on headphones while recording?
  • Douglas Villalba
    December 16, 2005 at 12:45 am
    Well we had our second day of shooting and everything went well. It happends that this particullar TV personality has a very estrange low frequency voice causing the mics to peak. We just had to keep the studio mic. 4 feet from him for the loops and instead of the Senn M67 we used a lesser quality mic.
    Douglas Villalba
  • John Fishback
    December 18, 2005 at 4:31 am
    I have a PMD670 and I looked through its menus to see if there might be a setting that would contribute to the problem you were having. Nothing obvious turned up. However, there is a 20db pad switch hidden under the panel on the top right that’s held in place by two screws. THe pad is either on or off. If it was off, try switching it on. That way you’ll attenuate the input signal by 20db. If the mic is overdriving the input pre, perhaps the pad would help eliminate the distortion.
    John
    Dual 2.5 G5 4 gigs RAM OS 10.4.3 QT7.0.3
    Dual Cinema 23 Radeon 9800
    FCP Studio 5
    Huge U-320R 1TB Raid 3 firmware ENG15.BIN
    ATTO UL4D driver 3.50
    AJA IO driver 2.1 firmware v23-28
    SonicStudio HD DAW, Yamaha DM1000, Genelec Monitors
