Activity Forums Apple Final Cut Pro Sound activated plugins for FCPX
  • Sound activated plugins for FCPX
    Posted by Evan Brindle on November 7, 2018 at 2:21 pm
    Hi all,
    I’m after a method to use the location sound (person talking) to effect the subtitles on screen.
    Anyone got any plugins they can suggest?
    Many Thanks
    Brett Sherman replied 7 years, 10 months ago 3 Members · 2 Replies
  • Mark Suszko
    November 7, 2018 at 7:33 pm
    In Motion, you can animate a behavior that’s linked to an audio source, then publish that to FCPX. I made a plug-in that way once to blink the screen to black on the loud drum beats of an incoming music track, it was the fastest way to make a lot of 1 and 2 frame cuts when the dj “dropped the beat”. Volume can also be used to keyframe changes in scale or other values, so a shout, for example, could drive the “wiggle” and scale effects to make a title seem to react or act in synch with someone shouting.
    That the kind of thing you’re looking for, or just a way to trigger titles to match in synch with dialogue?
  • Brett Sherman
    November 8, 2018 at 1:55 pm
    How is what you want to do different than just normal subtitles?
