Activity Forums Adobe After Effects SOS with Brief Animation
  • SOS with Brief Animation
    Posted by David Shaw on July 8, 2008 at 11:00 pm
    I’ve been trying to specifically animate a flourish that was created in Photoshop.
    The idea is that there is a person onscreen, holding an object, and the flourish is supposed to sprout out of the object as the person turns around. In addition to the growth of the flourish, I have to create a 3D effect, using the camera (I believe). The entire sequence will be 10 seconds maximum.
    Does anyone have any suggestions?
    Should I use a null object in this case to enable the camera? What might be the more effective way?
    Thank you
    David Shaw replied 18 years, 2 months ago 2 Members · 3 Replies
  • Jacob Wessler
    July 9, 2008 at 12:06 am
    David,
    Here’s one possible approach:
    You need to track your footage – either with AE’s tracker, or a 3rd party tracker (whatever you can afford!)
    Once that’s done, apply the tracking data to a null object – you can now parent all other layers to that null object and have them follow the rotation etc.
    Create a new composition for your flourish – create it from vector art from Illustrator (or other program) or use one of Andrew Kramer’s Evolution pieces (http://www.videocopilot.net). These things are awesome and totally worth the money!!
    As for camera movements, it’s easiest to use null objects (again, see Andrew Kramer for help Tutorial #54)
    Those should be some good places to start.
    Good luck,
    Jacob
  • David Shaw
    July 10, 2008 at 6:26 am
    Thanks for your help Jacob!
    I appreciate it.
    -David
  • David Shaw
    July 10, 2008 at 6:27 am
    Hi Dave,
    Your tutorial using the ‘write-on’ effect has been very helpful so far.
    Thanks a lot for your posting!
    -David
