Activity Forums Avid Media Composer SOS Mpeg streamclip gamma shift workaround
  • SOS Mpeg streamclip gamma shift workaround
    Posted by Timothy Miller on June 27, 2013 at 9:32 am
    Hi everybody !
    I am onlining a HD 1080i 25fps project in Paris.
    Several archive banks are delivering footage via ftp etc. in different file formats, some of them not supported by MC 6.5 for direct import.
    As I intend to output in avid 1×1 10bit for color grading, I am using MPEG Streamclip to convert these files to an avid ‘importable’ format.
    But I am encountering a SERIOUS GAMMA SHIFT in the resulting files. I am not certain wether this shift which shoves my footage into the infrablack netherland is destructive or not. If it is destructive, I have a problem !
    QUESTION : Does anyone know of this gamma shift problem? Is there a workaround? Does anyone know about an alternative software to MPEG Streamclip which does not produce same problem?
    FYI I am running Avid Symphony 6.5.2.25575 on a 5.1 MAC Pro OS 10.8.2
    Thanks for your answers.
    Timothy
    Timothy Miller replied 13 years, 2 months ago 2 Members · 2 Replies
  • John Pale
    June 27, 2013 at 2:30 pm
    [Timothy Miller] “some of them not supported by MC 6.5 for direct import.
    What formats might these be?
    Pretty much anything that can be thrown at you can be ingested by AMA linking and transcoding to Avid DNX HD. That will usually allow you to avoid any gamma issues introduced by QuickTime player or third party software.
  • Timothy Miller
    June 27, 2013 at 2:42 pm
    Some funky mpeg 4 disguised as .mps that I can only open with Quicktime AFTER having changed the extension to .mpeg.
    Upon trying to import these clips, AVID says “This type of Mpeg file is not supported” therefore the need to use Mpeg Streamclip to transcode it.
    One thought though, I have been transcoding directly to Avis 1×1 10bit before importing in Avid. Will try transcoding to dnx, import and then consolidate to 1×1.
    Will keep you posted!
    Just tried ama linking. None of my plugins support those files.
    Thanks for your answer.
    TImothy
