Activity Forums Avid Media Composer S.O.S. “cannot edit read-only track”
  • S.O.S. “cannot edit read-only track”
    Posted by Taracarey on April 29, 2006 at 1:26 am
    I hope someone can help me!! I’m editing on Avid Express Pro, using an AVID spec Dell 9300 PC with Windows. I dont know why but all of a sudden I cant edit on my programme timeline, when I try to make any changes a box comes up saying “cannot edit read-only track”. It only applies to my main timeline, on other smaller sequences its fine, what should I do? I tried creating a new project and copying it over but it still says ‘read-only’. Any advice greatly received…
    Thanks a lot!
    Tara
    Tara
    Justin Coleman replied 20 years, 4 months ago 3 Members · 2 Replies
  • Jon Zanone
    April 29, 2006 at 6:58 am
    Somewhere… and I’m trying to remember where… there is a ‘lock tracks’ command (maybe the clip menu?)…
    Do you have a little padlock to the left of your tracks?
    Jon
    “The Almighty tells me He can get me out of this mess. But He’s pretty sure you’re F%$#*D!”
  • Justin Coleman
    April 30, 2006 at 3:13 pm
    Did you make the project in another version of avid?
    It’s either a locked track or stream count issue. You either need to unlock the track or edit the whole sequence into a new blank sequence and it should sort it, if not you must be trying to use more streams than either the video or audio allows in you version of avid.
