Activity Forums Apple Final Cut Pro Legacy Sorry for duplicate. Please reply to other post. with same name. DVCPRO HD randomly references wrong clips or clip generators in timeline
  • Sorry for duplicate. Please reply to other post. with same name. DVCPRO HD randomly references wrong clips or clip generators in timeline
    Posted by Donovan Kosters on February 5, 2008 at 10:03 pm
    I’ve been working in a DVCPRO HD (1080p) timeline in FCP 5.1.4. When you move the playhead over certain clips which are not even rendered, do not need rendering, etc. footage that is not associated with it appears. Almost as if FCP is referencing the wrong clip. Usually, however, what shows up is a clip from another timeline an usually it is a text generator of some sort. If you pull another clip over it, then move it away, it disappears. Has anyone ever experienced this problem?
    I have tried trashing preferences as well as dumping all render files and letting the timelines rerender. The problem seems to be getting worse. Out of 8 systems there is only one that we have this problem on. Any suggestions would be much appreciated. Thanks!
    Donovan Kosters replied 18 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
