Activity › Forums › Apple Final Cut Pro › Sorry, edge selection question again…
  • Sorry, edge selection question again…
    Posted by Joshua Pearson on March 27, 2014 at 9:09 pm
    Once again I am asking if anyone else has totally inconsistent bracket-key edge selection behavior… i simply cannot get the key-command to work 90% of the time, but the strange thing is, once in a while it dies. The reason i want it to work so badly is that i have a LOT of dialog-only clips cut together very fine, individual words and nat sound etc. etc…. and i have applied a custom 3-frame audio dissolve to ALL the cuts, to smooth out pops etc. But supposedly i should be able to use the bracket key to select an edge, even with transition applied, if i want to trim or nudge the edit point. But, I cannot seem to get the bracket key to work even with no transition applied!… am i missing something obvious? Just two clips cut next to each other, i can select the edge with the mouse, but not with the [ or ] key. Except randomly once every 20 tries. Very frustrating.
    Joshua Pearson replied 12 years, 6 months ago 1 Member · 1 Reply
  • Joshua Pearson
    March 27, 2014 at 9:15 pm
    Answered my own question by searching older posts… playhead must be on edit point.
    sorry folks…
