Activity Forums Apple Final Cut Pro Legacy Sorenson Video 3 Decompressor in FCP7
  • Sorenson Video 3 Decompressor in FCP7
    Posted by Raju Bhai on December 25, 2014 at 5:21 am
    Hi I have a video I need to edit and these are the specs:
    Sorenson Viodeo 3 Decompressor, 720 x 480, millions
    16 bit integer (big endian)
    29.97
    It is just one 6 minute clip music video and I will be cutting some other external clips into it.
    My question is do I need to transcode this footage before editing in FCP7 or are these specs ok to edit with? And if it is OK, then what Sequence settings should I use? And if not OK, then what codec should I transocde this into?
    thank you
    Raju Bhai replied 11 years, 8 months ago 2 Members · 4 Replies
  • Shane Ross
    December 25, 2014 at 9:16 am
    [raju bhai] “My question is do I need to transcode this footage before editing in FCP7 or are these specs ok to edit with?”
    Gotta convert. FCP doesn’t edit that format.
    Convert to DV/NTSC.
    Shane
    Little Frog Post
  • Raju Bhai
    December 25, 2014 at 9:50 am
    thanks,
    can u tell from the specs i gave whether it’s HD or not? I know the footage was originally shot on a professional $100,000 digital video camera.
  • Shane Ross
    December 25, 2014 at 8:15 pm
    The file you have isn’t HD. It’s highly compressed and in an SD frame size. If you want it in HD, you’ll need to have them send an HD file. DNxhd, or ProRes…
    Shane
    Little Frog Post
  • Raju Bhai
    December 26, 2014 at 1:57 am
    Thank you Shane! I went ahead and transcoded and the editing has been smooth and problem-free!
    I also have some new footage for a different video that i’m wondering if needs to be transcoded, i posted that question in a separate post if you have a chance to check it.
    thanks
