Activity Forums Adobe Premiere Pro sorenson squeeze
  • sorenson squeeze
    Posted by Leon Klein on February 10, 2006 at 3:10 am
    Hello
    I am using sorenson squeeze to compress a movie but I am confuse with a two concepts..
    what does it mean when in frame rate says 1:1 , 2:1 and 3:1
    and
    what does it mean “key frame every X frames”
    thank you so much.
    leo
    Mike Velte replied 20 years, 7 months ago 2 Members · 1 Reply
  • Mike Velte
    February 10, 2006 at 11:46 am
    1:1 frame rate matches the source…2:1 doubles the frame rate of the source.
    Keyframes are used for indexing a clip, alowing one to skip forward or backward. The frames between keyframes are often not complete frames, depending on the type of compression, spatial or temporal. More keyframes makes for a larger file.
