Activity Forums Compression Techniques Sorenson Squeeze (V8) importing AVI problem
  • Sorenson Squeeze (V8) importing AVI problem
    Posted by Mike James on September 16, 2012 at 4:50 am
    Sorenson Squeeze importing AVI problem
    I exported an uncompressed Microsoft AVI file from Adobe Premier CS5.5, but when I try to import it into Sorenson Squeeze (8.5.0.41) it just shows a black screen in the viewing window. The sound plays perfectly, but there is no picture. Does anyone know what the problem might be?
    Here’s the MediaInfo on the file I’m trying to import:
    General
    Complete name : F:test.avi
    Format : AVI
    Format/Info : Audio Video Interleave
    Format profile : OpenDML
    File size : 49.2 GiB
    Duration : 11mn 45s
    Overall bit rate : 599 Mbps
    Recorded date : 2012-09-16T00:14:56.00861+01:00
    Writing application : Adobe Premiere Pro 5.5
    Video
    Format : YUV
    Codec ID : v210
    Codec ID/Hint : AJA Video Systems Xena
    Duration : 11mn 45s
    Bit rate : 597 Mbps
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate : 30.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:2
    Bit depth : 10 bits
    Compression mode : Lossless
    Bits/(Pixel*Frame) : 21.600
    Stream size : 49.1 GiB (100%)
    Audio
    Format : PCM
    Format settings, Endianness : Little
    Format settings, Sign : Signed
    Codec ID : 00001000-0000-0100-8000-00AA00389B71
    Duration : 11mn 45s
    Bit rate mode : Constant
    Bit rate : 1 536 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Stream size : 129 MiB (0%)
    Interleave, duration : 9937 ms (298.11 video frames)
    Hope someone can help.
    Mike.
    Mike James replied 13 years, 12 months ago 1 Member · 0 Replies
  • 0 Replies
