Activity Forums Compression Techniques Sorenson Squeeze reducing resolution by 2 pixels
  • Sorenson Squeeze reducing resolution by 2 pixels
    Posted by Ted Buras on April 29, 2009 at 4:48 pm
    I’m taking a 640×480 video and using Squeeze to transcode it (WMV file format). However, when it’s completed, the video is now 638×480. Just curious as to why this might be. I have tried setting the frame size setting to both “same as source” and 640×480 but the final video is still coming out at 638×480. Not a huge deal, but I can’t figure out why it’s doing that. Any ideas?
    Ted Buras replied 17 years, 4 months ago 2 Members · 6 Replies
  • Daniel Low
    April 29, 2009 at 11:25 pm
    [Ted Buras] “but the final video is still coming out at 638×480”
    What’s telling you it’s that frame size?
    Two years from now, spam will be solved. – Bill Gates, World Economic Forum 2004
  • Ted Buras
    April 30, 2009 at 5:34 am
    Media Player shows it as 638×480. I also loaded the file into Sorenson, and it too is showing that resolution.
  • Daniel Low
    April 30, 2009 at 7:36 am
    What if you use a format other than WMV?
  • Ted Buras
    April 30, 2009 at 3:06 pm
    Just rendered a clip in MOV and it also came out to 638×480. Hmph.
  • Daniel Low
    April 30, 2009 at 3:52 pm
    Have you grt any kind of cropping/resizing mashup going on in your profile?
    Does this happen with a fresh unused preset?
    What if you give it some other sized source?
  • Ted Buras
    May 2, 2009 at 12:40 am
    Used a new template but no luck.
    So I loaded a smaller video (480 x 360) and ran my current template on it (which is set to render at 640 x 480) and it came out 640 x 480. Changed the setting to “same as source” and it stayed at 480 x 360.
    Yet, when using the original 640 x 480 AVI, it comes out 638 x 480. Argh!
    BTW – thanks for your help with this!
