Activity › Forums › Compression Techniques › Sorenson Squeeze Preset Reverts Settings
  • Sorenson Squeeze Preset Reverts Settings
    Posted by Andrew Saliga on March 1, 2010 at 11:19 pm
    I’m having an issue running Squeeze 6 on both my Mac (Snow Leopard) and PC (Windows 7) where certain preset settings will revert without saving.
    For example, I created a custom filter for deinterlacing in Squeeze. I check the option to identify deinterlaced blocks, and after I click OK and re-open the preset I see it has reverted to off. This happens on the Mac and PC when using a custom preset, not trying to modify one that it ships with.
    -Andrew Saliga
    Steelehouse Productions
    http://www.steelehouse.com (undergoing a much-needed redesign)
    http://www.vimeo.com/steelehouse
    Andrew Saliga replied 16 years, 6 months ago 2 Members · 2 Replies
  • Daniel Low
    March 1, 2010 at 11:51 pm
    Heard back from Sorenson support?
    Sent from my iPad Nano.
  • Andrew Saliga
    March 3, 2010 at 5:41 pm
    Now that I think about it, it did seem more like a software issued that would need to be addressed by Sorenson.
    Either way, I contacted support. The check box to “Identify deinterlaced blocks” is not something to assist with the actual deinterlacing process. Although it’s found in the filter settings and there is already a “Preview” check box, this is just another check box that shows you parts of the image that are already deinterlaced.
    -Andrew Saliga
