Activity › Forums › Compression Techniques › Sorenson Squeeze – Extra Frame
  • Sorenson Squeeze – Extra Frame
    Posted by Robin Farley on October 21, 2010 at 6:14 pm
    I’m quite familiar with various compression techniques and software. However, Squeeze is driving me nuts – it appears to be adding an extra frame to videos I encode to H.264 .mov format.
    Has anyone experienced this before? It’s only a single frame. I’ve looked at Sorenson’s site – they say the encoding process cannot add frames. Did I hit something? Or is there an issue with the source file? The single frame is crucial b/c I’m encoding for animation.
    Also, any suggestions on how to maintain the source color, contrast, and gamma for H.264 without messing with filters?
    Any thoughts would be much appreciated.
    – Robin
    Andrew Saliga replied 15 years, 11 months ago 2 Members · 1 Reply
  • Andrew Saliga
    November 3, 2010 at 4:45 pm
    I’ve had this issue as well (except with MPEG-2 encodes), and unfortunately to do not know a solution.
    Andrew Saliga
    I/O Specialist/Assistant Editor
    Steelehouse Productions
    http://www.steelehouse.com
