Activity Forums Compression Techniques sorenson squeeze
  • sorenson squeeze
    Posted by Chris Mclaughlin on July 4, 2009 at 1:36 am
    Hi I dont know if this is where I post this but here it goes…If I use sorenson squeeze to encode for DVD how do I achieve final output for DVD with 16:9….the footage I have created and imported is all 720×480 created in a DV NTSC widescreen comp setting in after effects 5.5…its exported as a quick time file as 720×480 with no compression. can I use the dvd 16:9 lg template in sorenson and set the aspect ratio to 16:9…i want the end product to be 16:9 on a widescreen tv and a widescreen computer screen
    thanks
    Daniel Low replied 17 years, 1 month ago 2 Members · 1 Reply
  • Daniel Low
    July 6, 2009 at 10:22 am
    [chris mclaughlin] “can I use the dvd 16:9 lg template in sorenson and set the aspect ratio to 16:9…i want the end product to be 16:9 on a widescreen tv and a widescreen computer screen”
    Yes, assuming your workflow up to this point has been correct.
    Two years from now, spam will be solved. – Bill Gates, World Economic Forum 2004
