Activity Forums Compression Techniques Sorenson resizes avi issue
  • Sorenson resizes avi issue
    Posted by Michael Hussar on April 19, 2008 at 5:02 am
    using: Windows xp pro sp 2 dual xeon 4 gigs of ram
    flash 8 sorenson squeeze 4.2
    Hi I just watched Internet Killed the Video Star. So now I’m pretty jacked up on compression 🙂
    I tried compressing an avi with using Sorenson. I converted it to a flv with the VP6_Lg_prog preset. I tweaked the settings – increased the data rate and decreased key every frame. checked compressed alpha since I’ll be compositing this movie in Flash with other elements. I set the frame size to the original size of the avi.
    1. I import the flv file into flash as an embedded swf.
    2. I Test Movie and it looks great, although strangely larger its original dimensions.
    3. When I open the swf directly from windows explorer, the
    swf shows smaller than it’s original dimensions and has the tell-tale distorted look of a movie file that has been resized in Flash.
    Any help is appreciated
    thanks
    Michael
    Daniel Low replied 18 years, 5 months ago 2 Members · 1 Reply
