Activity › Forums › Adobe Premiere Pro › Sorenson quicktime codecs
  • Sorenson quicktime codecs
    Posted by Rick Ag on October 1, 2009 at 1:57 am
    Does anyone knows why the sorenson quicktime codecs are not installed to the codecs library on the new CS4 (after effects, Premiere Pro, PS CS4) for some reason I have them in older versions CS2 and CS3 but not in the CS4 (none of them have them) and of course I installed the full the CS4 Production Premium directly from the original package with all the options
    Does anyone knows any prooved way to add this codecs to the CS4 codecs libary, you know it has a very good quality video codec in a small size compression
    Thank you in advance
    skydivemail@yahoo.com
    Rick Ag replied 16 years, 12 months ago 2 Members · 2 Replies
  • Mike Velte
    October 1, 2009 at 10:29 am
    All the old legacy QT codecs are still there including sorenson. There is no Preset, but on the Video Codec tab in the AME is a drop down list.
  • Rick Ag
    October 4, 2009 at 1:33 am
    Thanks for your Help Mike, yes another user in Apple told me the same,(Advanced tab in QT and enable old legacy codecs) thanks for the valuable info,
    This is very interesting so if apple declared Sorenson obsolete, so which could be the best video codec with approximately the same size rate of space in files than sorenson 3 ? , sorenson 3 was not bad and a small difference in quality than Photo Jpeg or Jpeg2000 codecs but a big difference in size ratio, by the way I have tried the quicktime H.264 in the best posible quality but it’s terribly poor
    So which could be a better codec than sorenson 3 but with approx. the same size ratio in files ?
    Thanks for your help !!
