Activity Forums Compression Techniques sorenson compression suite 4.1 – F4M/wmv/MBR weirdness
  • sorenson compression suite 4.1 – F4M/wmv/MBR weirdness
    Posted by Billy Earle on May 18, 2005 at 8:07 pm
    Hi all. Just purchased F4M Studio Pro (along with F4M and Ben’s class on demand for Squeeze – nice job, Ben). Running on dual2g G5/4g ram OSX10.3.5 and using Sorenson Compression Suite 4.1
    I have all the presets for wmv except for MBR. When I create an MBR and apply it to a QT file (exported from AVID Adrenaline MC as QT – animation) and press “squeeze it”, the progress bars advance to 2% and stop. I’ve let it sit for hours and nothing changes. The result is a 5 second clip (of a 4 min vid) and a ~70kb file.
    F4M is activated.
    I’ve successfully compressed this file using every preset under the WMV tab, but cannot make an MBR work.
    It’s also interesting to note that if I change any of the presets, the same hang-up occurs.
    Has anyone had this problem? I’ve searched the web over and thought I found true love, but you met another…er, uh, what I meant to say was that I’ve looked and looked and can’t seem to find any info concerning Sorenson 4.1/F4M/WMV/MBR.
    Any help would be viewed as a good thing and lavished with praise. In a perfect world, I’d be able to download some MBR presets.
    Here’s to hump day…
    ^billy
    Billy Earle replied 21 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
