Activity › Forums › Sony Cameras › Sony XDCAM EX Transcode question
Posted by Brian Stenson on January 16, 2009 at 11:04 amHey guys. Project shot with EX-1, XDCAMEX 25fps. I have a mac at home with FCP 6.0.4 but in work we still only run 6.0 with Blackmagic cards. I’ve tried transcoding at home to a few different codecs incl Blackmagic 8bit and 10bit, HDV and Apple ProRes and I get horrible results.
File-size isn’t an issue, I just want big crisp clear pics. How should I transcode, format-wise? 🙂
Cheers for any help.
B
Rafael Amador replied 17 years, 8 months ago 4 Members · 5 Replies -
Rafael Amador
January 16, 2009 at 11:09 amHad you set “Render all YUV material in High Precision YUV” when rendering in a 10b codec?
Are you resizing? If so set Render Motion Effects: BEST.
Cheers,
Rafael -
Brian Stenson
January 16, 2009 at 11:17 amThanks Rafael, will try that tonight.
All the best and I’ll let you know.
Steve Connor
January 16, 2009 at 11:45 amCan your work just not upgrade to the latest FCP version? it’s all very stable especially with BMD cards
Steve Connor
Adrenalin TelevisionHave you tried “Search Posts”? Enlightenment may be there.
Kevin Jones
January 17, 2009 at 7:11 pmRafael,
Could you please explain what “Render all YUV material in High Precision YUV” does to improve the look of SD renders?
Also, I wanted to compliment you on the beautiful video on your website.
Has a very nice almost 3-D look!
How are you achieving the vignette you use?
Looks great.
Thanks.Kevin Jones
2.5GHz Quad-core PowerPC G5
Final Cut Studio 2 -
Rafael Amador
January 18, 2009 at 3:04 amHi Kevin,
When you set “Render all YUV material in High Precision YUV”, FC works in 32b Floating point mode.
That mean that any transformation/effect applied to your footage is done with much higher accuracy.
The rounding errors that occurs when working with 8b are minimized. This is important when you apply few filters to your stuff. The picture will benefit from this better rendering even if you export back to just 8b.
Setting “Render Motion Effects: BEST” is also important when downscaling from HD to SD. This mode you set FC to work with the higher level of quality that the application offers.
Thanks for the comments on my humble website. The clip in he font with the PD170P and I make the vignette with the old MagicBullet.
I would like you to have a look to this clip that is done with the EX-1:Hope you like it.
Cheers,
rafaelSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
