Activity Forums Sony Cameras Sony XDCAM EX Clip Browser
  • Sony XDCAM EX Clip Browser
    Posted by Holly Dubkoff on June 27, 2011 at 6:02 pm
    I bought this product but it is not installing correctly. When I export to MXF there is still a watermark on the footage when I import back into AVID. Please Help!
    Ian Cook replied 15 years, 3 months ago 3 Members · 7 Replies
  • 7 Replies
  • Craig Seeman
    June 27, 2011 at 6:29 pm
    XDCAM Clip Browser is a free download from Sony’s Pro site.
    MXF for NLE is free. The other MXF export functions may require a purchase of the components from MainConcept. If you’re just trying to create and MXF file for editing use the free MXF for NLE export function.
  • Holly Dubkoff
    June 27, 2011 at 6:43 pm
    I purchased the components from Main Concept.
  • Ian Cook
    June 27, 2011 at 6:44 pm
    As Craig suggested, use the first MXF option, “MXF for NLE.” This is for older versions of Avid, Premiere etc that do not support direct import of EX files. This selection changes the file wrapper without transcoding. The other options transcode the video contents to the selected XDCAM codec and are generally used when you need to put the files onto an XDCAM optical disc.
    Also– if you have a recent version of Avid you can use AMA to access the files directly. Go to the Settings area–>AMA and enable ‘AMA Volume Mounting.’ Then connect your card or, if you’re reading from an archive, select File–>Link to AMA volume.
  • Holly Dubkoff
    June 27, 2011 at 6:46 pm
    That is the problem. I tried importing AMA into Avid. I’m pretty sure there are a couple corrupted files because i tried everything and they would not import into AVID.
  • Ian Cook
    June 27, 2011 at 6:56 pm
    are there errors (onscreen or in Console) or does Avid just say “0 of X clips imported.” at any rate, yes, if the video/audio/TC are intact the MXF rewrap using CB should work.
  • Holly Dubkoff
    June 27, 2011 at 7:05 pm
    errors on screen AND in console. CB did not install right apparently, there is still the watermark on the clips after export.
  • Ian Cook
    June 27, 2011 at 7:10 pm
    if you’re referring to the clips already exported, the watermark is part of the video and can’t be removed. you need to re-export. make sure you use the first option, ‘MXF for NLE.’ under no circumstances should that add a watermark to the video.
