Activity › Forums › Adobe Premiere Pro › Sony XD-Cam .MOV’s Don’t Play Nice in Premiere Pro…?
  • Eric Addison
    May 7, 2012 at 6:47 pm
    [Darren Kelly] “1. Premiere Pro 4 wasn’t a native XDCAM software, so it doesn’t know how to handle the files. Remember you are running 3 major releases behind.”
    XDCAM EX support came in CS3, so it should be there in CS4. I believe the issue is that the files have been wrapped into a .mov file that is optimized for FCP – Premiere Pro likes the native .mp4 files that come straight from the camera.
    —Eric
    Owner | 100 ACRE FILMS
    https://www.100acrefilms.com
  • Todd Wiseman
    May 7, 2012 at 6:54 pm
    I think this is pretty much the answer. Thanks for your input. I do hope that CS6 will have better support for the FCP-optimized XDCam MOV’s, because I really do have a lot of them and will definitely need to use them on a daily basis for years to come. If not, I’ll look into the decoding option you mentioned. I’ve read good things about it.
  • Todd Wiseman
    May 7, 2012 at 6:58 pm
    Believe me, it saddens me to leave the Final Cut Pro camp. I was a certified trainer for a couple of years and love that program to death. I am much more comfortable with it and am not yet convinced Premiere is an improvement. I really just feel that moving forward, FCPX is not going to work for our needs. It may get better and I may return to it later but Premiere is looking better and better with every version and I have a lot of confidence in Adobe and its commitment to professionals. Apple, I believe, is headed in other directions. Thank you for your input.
  • Todd Wiseman
    May 7, 2012 at 7:01 pm
    Excellent point. Thank you. I’m hoping CS6 will chomp through those MOVs a little better, especially if I grab a more ram. A little worried that Apple won’t be updating the towers. Are most Premiere users on PCs you think?
  • John-michael Seng-wheeler
    May 8, 2012 at 7:18 pm
    just a note about the XDCAM .MOVs: The XDCAM quicktime codecs are Mac only, (they’re installed by FCP,) so if you ever need to switch to Windows use them on windows you’ll have to unwrap them.
  • Mark Stuart
    May 18, 2012 at 3:05 pm
    In the same boat, I couldnt understand why XDCAM transfer .mov’s from OSX wouldnt play on PC. This thread confirms!
    In my case I will re-ingest native .mxf from XDCAM discs but if I had a large library, slightly annoying having to pay out $90 for a 3rd party solution. https://www.calibratedsoftware.com/store/item_view.asp?estore_itemid=1000002
    Regards
    Mark
Page 2 of 2
