Activity › Forums › Avid Media Composer › sony XAVC problem
sony XAVC problem
Posted by Pieter Smet on October 9, 2013 at 12:53 pmHello,
I’ve got some sony f5 footage on a hard disk. It was shot in a XAVC codec, with variable frame rates.
I have 4 cards, 2 of them have been copied correct (all folders are still there: I have the ‘XDROOT’ with all other files in it). Via AMA Avid recognizes those 2 cards immediately.
But, from the 2 other cards I only have the content of the ‘clip’ folder. I can play all the files in VLC, but Avid doesn’t recognize the files. How can I fix this?It is pretty urgent, and don’t know what to do, so all help is welcome!
P.
Bárbara Nunes replied 11 years, 2 months ago 7 Members · 12 Replies -
Michael Phillips
October 9, 2013 at 9:39 pmI tried importing a single MXF wrapped XAVC file into Sony Content Browser, and while that part worked, I could not export it as anything useful. I was able to the open the files in Resolve Lite and export from there to MXF/DNxHD of my choice with no problems.
Michael
Glenn Sakatch
October 10, 2013 at 3:22 amCan you not do a manual select of the clips from those cards. Set your Ama selection to the file type and select all the clips. My first testing with f55 didn’t have the proper folder structure. Not sure if f5 is pickier or not
Glenn
Michael Phillips
October 10, 2013 at 11:48 amI tried that with the MXF AMA plug-in and it did not work for me.
Michael
John Pale
October 10, 2013 at 4:56 pmWhat is the frame rate/format of the footage.
I had a disk shot with the F5 not work at all via AMA that was shot at 1080p50.
Pieter Smet
October 11, 2013 at 7:58 amWhen I just try to link to a single AMA file I get this message in my source window: ‘core consistency check failure’ So no luck with that.
Resolve is giving me a hard time, my GPU memory is always full.Some footage on the card is 1080p50 others 1080p25.
Hope to solve this problem soon, thanks for the help so far!
Gr,
P.
Glenn Sakatch
October 11, 2013 at 8:43 pmDoes seem flakey. I have a project sitting here where i have linked to clips in the proper structure, but am now having issues linking to those same clips in a different project.
I have also had success with single clips sent to me as tests, as well as clips i’ve downloaded off the WEB
but today, no such luck.Glenn
Michael Phillips
October 11, 2013 at 9:41 pmTry a 720p/50 project in Resolve. I have done 1080/59.94 that way from Canon cameras.
Michael
Pieter Smet
October 11, 2013 at 10:38 pmJust made a prores file with https://www.ffmpeg.org/
you need some command line and scipting but it works! -
Chris King
November 8, 2013 at 1:59 amIn fact, Avid has supported Sony’s MPEG2 format for many years now, and was first out of the gate to support XAVC HD. Like most Avid workflows these days, video is imported via Avid Media Access (AMA). To make this work for both MPEG2 & XAVC HD you’ll need to install the XAVC/XDCAM Plug-in for Avid (PDZK-MA2).
Once installed, launch Avid Media Composer and you can import your Sony XAVC videos in usual. However, it’s a pity we still find that there are still some issues occurred from time to time during the importing and editing process.
We find that with the plug-in, Avid still can’t ingest long footage. And what we need to keep in mind that 4K XAVC footage is not currently supported, so you will get an error if you try to import it. Plus, Avid does not have a 60p project format so you will most likely be working in a 60i (interlace) type project.
To avoid these problems, it will be better to transcode Sony XAVC to a more “edit” friendly codec.
https://video-playback-tips.com/
