Activity › Forums › VEGAS Pro › Sony Video 8 Pro Editing Sequence
  • Sony Video 8 Pro Editing Sequence
    Posted by Alfred Morley on November 11, 2011 at 10:53 pm
    I have the Sony Vegas Pro 8 video editing program and render to Mpg 2
    I have been advised to have the actual program on C: Drive.
    All video clips and project files on D: Drive
    Export finished project to E: Drive
    Would this be correct?
    Are there any other factors that I should take into consideration?
    Thanks for any help and advice. Alf Morley.
    Reply please to:(alfredsvideo@gmail.com)
    Stephen Crye replied 14 years, 10 months ago 2 Members · 1 Reply
  • Stephen Crye
    November 12, 2011 at 12:17 am
    Hi Alfred;
    If all your drives are fast SATA, I would say that is a good setup. the idea is to keep the heads on any drive from having to whip back and forth between reading and writing.
    But, if some of your drives are USB, then the config you proposed might be slower than having some of the functions on the same, fast drive.
    Last year I did a bunch of tests on my system to come up with the optimal configuration. What I noticed is that it did not make a big difference, because my system is CPU-bound, not IO bound. I recommend installing Process Explorer to keep an eye on performance.
    Good luck and have fun!
    Steve
    Win7 Pro X64 on Dell T3400, MultiTB SATA, 8GB RAM Vegas 10e x64 DVDA 5.2(build 133) Sony HDR-CX550V
