Activity Forums VEGAS Pro Sony Vegas x264wfv output changes red color
  • Sony Vegas x264wfv output changes red color
    Posted by Levan Katsadze on March 22, 2015 at 5:11 pm
    Hello, I have Sony Vegas Pro 13 x64, and I am trying to render a video.
    When I render normally, with Sony AVC codec or MainConcept AVC, the output colors are just the same as input video.
    But I want to x264wfv plugin to render the video into x264 (lossless or maybe CRF), I like x264wfv more, because I can focuse on quality than bitrate. Sony AVC and MainConcept AVC are actually headache in terms of outputing maximum quality with not huge size.
    So, well, I rendered the video with x264vfw, here is the image of rendering settings:
    and here is the ouput:
    As you can see, the output video colors are almost identical, but only red colors are lighter than original video. I don’t understand, what’s wrong with x264wfv? Why it does not just make everything the same? why it changed red colors?
    Well, I just want totaly same output in terms of color.
    Steve Rhoden replied 11 years, 5 months ago 3 Members · 5 Replies
  • Steve Rhoden
    March 23, 2015 at 7:10 am
    Well, i dont know about x264wfv plugin, as that is not a Vegas
    problem, it would be best for you to get in touch with its
    developers and relate this same issue to them.
    Steve Rhoden (Cow Leader)
    Film Maker & VFX Artist.
    Owner of Filmex Creative Media.
    Samples of my Work and Company can be seen here:
    https://www.facebook.com/FilmexCreativeMedia
  • John Rofrano
    March 23, 2015 at 10:59 am
    May try using RGB instead of YUV? Your source is probably RGB and you may be loosing something on the color conversion. (just a guess)
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Levan Katsadze
    March 24, 2015 at 11:29 pm
    Wow, Finally! I did it! I fixed this problem.
    After soooooooo much Googling and testing and Googling and testing and testing, here is what I did finally:
    At first, I’ll say that this is the information of the source file:
    Downloaded from: Youtube
    Resolution: 3200×1800 (almost 4K)
    Framerate: 30fps
    Bit depth: 8 bits
    Color space: YUV
    Duration: 3 hours and 41 minutes
    And, well, the Project Properties in Sony Vegas:
    Pixel format: 32-bit floating point (video levels)
    –> NOTE: the colors in Sony Vegas Preview window was absolutely the same as source colors. I mean, there was no problem about studio RGB vs Computer RGB.
    And, this is what I did:
    I just typed this text in the command line tool in x264wfv window:
    –range pc –colormatrix bt709
    That’s it. It just rendered fine. Absolutely the same color output as source.
    Video editing is cool 😀 Big headache, but cool 😀
  • John Rofrano
    March 24, 2015 at 11:35 pm
    Wow. Glad you figured it out and came back to share with the community. That’s what makes the COW forums great! 😉
    ~jr
  • Steve Rhoden
    March 25, 2015 at 1:07 pm
    Good you got that sorted!
