Activity Forums VEGAS Pro Sony Vegas Video – Pan/Zoom using Parent Motion
  • Sony Vegas Video – Pan/Zoom using Parent Motion
    Posted by Brad Miller on October 11, 2009 at 10:45 pm
    want to pan and zoom around a bunch of photos and videos using Sony Vegas Video.
    The problem I have run into is that I am limited by my project setting resolution. So if my project is 1440 x 1080, I cannot use parent motion to zoom out to see all the child tracks beyond 1440 x 1080.
    This means that any photos or video that I want to pan to has to be small enough to fit within those bounds, therefore, around 300×200.
    Here’s a quick example I made, and as you see, the photos are low resolution in order to be small enough to pan between. vimeo.com/7014885
    Anyone know how to work around this? Or do I have to abandon Vegas and use After Effects. I would like to be able to create something similar to this: revostock.com/After-Effects-Project/83793/Deluxe-Contact-Sheet.htm
    Bob Peterson replied 16 years, 11 months ago 3 Members · 12 Replies
  • 12 Replies
  • Steve Rhoden
    October 12, 2009 at 1:45 am
    There is no limitation in the task you are trying to do….
    you only need to use the track motion features.
    Steve Rhoden
    (Cow Leader)
    Creative Arts Director and Film Maker.
    Project Samples at:
    http://www.youtube.com/hentys
  • Brad Miller
    October 12, 2009 at 2:22 am
    The size of my monitor has nothing to do with what I’m talking about. I’m talking about the Vegas project settings. It limits you to 2,048×2,048.
  • Brad Miller
    October 12, 2009 at 2:27 am
    I am using track motion. I cannot extend the images and videos beyond the the frame size my project is set at. That’s the problem.
    So if I want to pan between multiple images, they all have to be at resolutions smaller that whatever my project settings are, which Vegas 8 limits to a maximum of 2048×2048.
    Here’s an example I made depicting the problem: https://www.vimeo.com/7014885
  • Brad Miller
    October 12, 2009 at 2:39 am
    This person disagrees with you and states that there is a limitation:
    https://forums.creativecow.net/readpost/24/900236
  • Bob Peterson
    October 12, 2009 at 3:51 am
    Lots of people may disagree. That doesn’t mean they are correct.
    I don’t know what you are trying to achieve, but I just implemented a panoramic image (photo) in an SD project. I was able to get it to full vertical size, and pan across the horizontal dimension using Pan/Crop. I simply set the “Maintain Aspect” control to “No”, and selected the preset “1:1 Square Aspect Ratio”. I also manually adjusted the zoom settings to see what I wanted to see. It may take some experimentation to get it to look right, but I was able to do exactly what I wanted which is to pan across a fairly wide image.
  • Brad Miller
    October 12, 2009 at 1:04 pm
    You’re correct, there’s no problem panning across a single image…. I’m talking about tracking motion across multiple images and video as in the example I made and linked to.
  • Bob Peterson
    October 12, 2009 at 1:29 pm
    If it is multiple images, then, as noted, track motion can handle the job without a problem. It ceases to become an issue of project dimensions and converts to the need to manage multiple tracks with track motion. Individual tracks may need Pan/Zoom processing in addition to track motion. It’s all very doable.
  • Brad Miller
    October 12, 2009 at 1:56 pm
    That would only seem to work if you wanted each track to move independently. I want all tracks to move releative a fixed point as in the example I linked to. Something similar to this: https://www.revostock.com/After-Effects-Project/83793/Deluxe-Contact-Sheet.htm
  • Bob Peterson
    October 12, 2009 at 3:18 pm
    One thing I’ve learned over the years. There does come a point where you have to do some work. Coordinating the movement of tracks is not difficult. It simply requires some effort. It does allow complete control over what each track is doing.
  • Brad Miller
    October 12, 2009 at 3:37 pm
    Track Motion reduces the photo/video’s resolution to the project property’s resolution. So yes, I can create that effect, as I posted twice now, I already have.(https://www.vimeo.com/7014885). I used the excellent tutorial “Vegas Keyframe Interpolation Envelopes” by D. Eric Franks. It works fine if you keep the project small, as he did, just a small “postcard”
    However the resolution of the individual photos becomes too low if you want to include many images and video because Sony Vegas limits you to the project property’s resolution for the parent track. So unless you can up the project property resolution to something like 4,000×4,000, I can see no way to achieve this same effect which the photos at a decent resolution.
